Windows 10: Volume Shadow Copy - Win 10 problems - solution provided
Discus and support Volume Shadow Copy - Win 10 problems - solution provided in Windows 10 Installation and Upgrade to solve the problem; Hi moderator The thread old thread has a solution as descibed in new thread Could you pls. add? br Peter Lauritzen... Discussion in 'Windows 10 Installation and Upgrade' started by plauritz, Feb 24, 2021.
  1. plauritz Win User
    Hi moderator
    Could you pls. add?
    br Peter Lauritzen
  2. Volume Shadow Copy - Win 10 problems
    Hi Göran,
    There are several reasons why the error shows when creating a System Restore. In some cases, it can be due to multiple backup solutions installed on your PC that causes conflict. For us to better assist you, we would like to ask for additional information.
    Please answer the following:
    • Do you have another backup solution in your PC aside from the one provided by Microsoft?
    • Have you tried checking the Windows Services if the Shadow Copy, Task Scheduler, and
      Microsoft Software Shadow Copy Provider service are running?
    We hope to hear from you soon.
    Jennifer Cha, Feb 24, 2021
  3. Volume Shadow Copy Service error: A critical component required by the Volume Shadow Copy service is not registered.
    Thank you for getting back with a reply.
    I suggest you to start the Volume shadow copy service and check. Follow these steps:
    a. Click Start and type services.msc in the search box.
    b. Search for the Volume shadow copy service and make sure the start- up type is automatic.
    i. Right click on the service
    ii. If the service is stopped, then Start the service
    iii. Select Properties
    iv. And in the Start-up type select Automatic.
    c. Click Ok.
    Keep us posted on Windows related queries and we will be happy to assist you further.
    Nachappa C K, Feb 24, 2021
  4. biconix Win User
    I am getting a bunch of errors in the application log related to the Volume Copy Service. I first noticed it when I tried to create a recovery drive and the error simply said that "A problem occurred while creating the recovery drive"
    I examined the application log and noticed that this error occurs periodically, not only when I try to create the drive. I included the four errors below.
    What do I need to do to fix this?
    I am using a Surface pro 4, windows 10 with up to the minute patches. I also have installed carbonite but I doubt this is the cause as I did not encounter this problem on previous PCs
    Thanks in advance for any assistance
    Volume Shadow Copy Service error: A critical component required by the Volume Shadow Copy service is not registered. This might happened if an error occurred during Windows setup or during installation of a Shadow Copy provider. The error returned from CoCreateInstance
    on class with CLSID {3e02620c-e180-44f3-b154-2473646e4cb8} and Name SW_PROV is [0x80040154, Class not registered
    Operation:
    Obtain a callable interface for this provider
    List interfaces for all providers supporting this context
    Check If Volume Is Supported by Provider
    Add a Volume to a Shadow Copy Set
    Context:
    Provider ID: {74600e39-7dc5-4567-a03b-f091d6c7b092}
    Class ID: {3e02620c-e180-44f3-b154-2473646e4cb8}
    Snapshot Context: 4194304
    Execution Context: Coordinator
    Provider ID: {00000000-0000-0000-0000-000000000000}
    Volume Name: \\?\Volume{acda900a-c1f6-4b66-831d-a54d0f93e6db}\
    Volume Shadow Copy Service error: Error creating the Shadow Copy Provider COM class with CLSID {3e02620c-e180-44f3-b154-2473646e4cb8} [0x80040154, Class not registered
    Operation:
    Context:
    CoCreateInstance on class with CLSID {3e02620c-e180-44f3-b154-2473646e4cb8} and Name SW_PROV is [0x80040154, Class not registered
    Operation:
    Context:
    Operation:
    Context:
    biconix, Feb 24, 2021
  1. Volume Shadow Copy - Win 10 problems - solution provided - Similar Threads - Volume Shadow Copy
  2. Volume shadow copy error
    Volume shadow copy error: Event viewer error.Unexpected error calling routine ConvertStringSidToSidS-1-5-21-442981339-3756801702-44240739-1001.bak hr=0x80070359.The security structure is invalid.Any clues, please?...
  3. Volume shadow copy error
  4. Volume shadow copy error
  5. Shadow copy creation returns value 10 Shadow copy provider vetoed the operation
    Shadow copy creation returns value 10 Shadow copy provider vetoed the operation: OS: windows 10 ProBuild: 21H1I got 10 as return value when I try to create a new shadow copy.Searching, I found this microsoft articlehttps://docs.microsoft.com/en-us/previous-versions/windows/desktop/vsswmi/create-method-in-class-win32-shadowcopy10 value indicates "Shadow...
  6. Shadow copy creation returns value 10 Shadow copy provider vetoed the operation
  7. Shadow copy creation returns value 10 Shadow copy provider vetoed the operation
  8. "The shadow copy provider had an error 0x80042306"
    "The shadow copy provider had an error 0x80042306": After trying to create a system restore point, I got the error message in the title. I have tried all of the solutions I have read about using VSSadmin and SFC, and set VSS to start automatically, delayed. These do not fix the problem. I believe the problem is rooted in...
  9. Each reboot MS Software Shadow Copy Provider and Volume Shadow Copy do not "START"
    Each reboot MS Software Shadow Copy Provider and Volume Shadow Copy do not "START": Since some recent updates by MS including the massive Win 10 next generation, after each reboot MS Software Shadow Copy Provider and Volume Shadow Copy do not "START". When I check them in services.msc, they are usually in Startup Type set to Automatic (not manual or...
  10. Microsoft Software Shadow Copy Provider
    Microsoft Software Shadow Copy Provider: Hi. I am having a technical issue with my Windows 10 OS I don’t want to have to do a Factory restore it’s not big issue I am having it’s the issue with Microsoft Software Shadow Copy Provider. I went in to the Registry and fixed one of the values I had to fix this one...
