Windows 10: Volume won't mount unless HFS+ is running but it's NOT HFS+
Discus and support Volume won't mount unless HFS+ is running but it's NOT HFS+ in Windows 10 Drivers and Hardware to solve the problem; This is a weird issue I can't seem to resolve. Here we go: I have a PC running Win10. Attached is a 4-bay USB3 enclosure with all bays occupied. When I... Discussion in 'Windows 10 Drivers and Hardware' started by rumplestiltskin, May 4, 2021.
Volume won't mount unless HFS+ is running but it's NOT HFS+ - Similar Threads - Volume won't mount
How to delete HFS+ partition from USB drive?
in Windows 10 GamingHow to delete HFS+ partition from USB drive?: I have a flashdrive with a HFS+ partition on it. This partition is not visible in disk management or diskpart. However, it is listed in stellar data recovery but cannot be removed using that program. How should I go about removing the partition so it will be useable?... -
in Windows 10 Software and AppsHow to delete HFS+ partition from USB drive?: I have a flashdrive with a HFS+ partition on it. This partition is not visible in disk management or diskpart. However, it is listed in stellar data recovery but cannot be removed using that program. How should I go about removing the partition so it will be useable?... -
Formatted one of my drives to hfs+ and now windows 10 won't boot and stuck in bios
in Windows 10 Installation and UpgradeFormatted one of my drives to hfs+ and now windows 10 won't boot and stuck in bios: Asus laptop gl531g i7-9750H/BGA,hdd: 1tb ssh8g + 256g pcie, windows 10 64bit. I migrated my windows 10 to the d drive 1tb hd and formatted the c drive to hfs+ now windows 10 wont boot and is stuck in bios. Bios won't recognize any drives any not sure how to repair my... -
How to use Mac formatted HFS+ Drive on Windows
in Windows 10 NewsHow to use Mac formatted HFS+ Drive on Windows: [ATTACH] File management plays the most crucial role on a computer system. It controls how data are stored, organized and retrieved from a storage medium. In other words, it simply separates data on the drive and tags them with filenames and [...] This post How to use Mac... -
Bsod after hfs+ paragon driver install, "inaccessible boot device"
in Windows 10 BSOD Crashes and DebuggingBsod after hfs+ paragon driver install, "inaccessible boot device": Bsod after installing paragon hfs4win driver. Wont boot into any mode, including safe mode. Only have the troubleshoot menu and the command prompt. Unfortunately i cant restore my system either. i get an error about 15 minutes after i start that process saying the... -
BSOD because of HFS+ (INACCESSABLE_BOOT_DEVICE)
in Windows 10 BSOD Crashes and DebuggingBSOD because of HFS+ (INACCESSABLE_BOOT_DEVICE): I forgot to uninstall the Paragon HFS drivers... now can't access my computer. So I reverted to 10586, but it still pops up. How do I fix this? Sure, my HDD is still accessable through cmd, but I can't access Windows. After automatic reboot, I can't even access recovery... -
HFS+ from Mac to Windows - Formatted?
in Windows 10 Drivers and HardwareHFS+ from Mac to Windows - Formatted?: I was using an HFS+ 3TB Buffalo hard drive on my iMac and plugged it into my laptop running Windows 10 Tech Preview. It didn't show up in Explorer but I think I may have formatted it in Disk Utility. Somewhere along the way, a dialog popped up that mentioned a choice between... -
How to eject HFS-formatted drive from PC
in Windows 10 Drivers and HardwareHow to eject HFS-formatted drive from PC: I have plugged an HFS-formatted drive into my pc. With HFS Explorer I can access the data on the Mac-formatted drive, but I cannot find a way to eject the HFS-formatted drive since it does not show up at all in "This PC." How can I eject this drive properly? Possibly via... -
INACCESSIBLE_BOOT_DEVICE after installing Paragon HFS+
in Windows 10 SupportINACCESSIBLE_BOOT_DEVICE after installing Paragon HFS+: Basically I had a Win10 Pro 64bit installation running on my PC. Then I downloaded and installed Paragon HFS+ in order to read from my HFS+ drive. After the installation was complete, I restarted my PC. Instead of booting into Win10, the PC booted into a blue screen with...
