Windows 10: W10 Home PCs seeing only Win7 Pro & W10 Pro PCs on LAN, Not Home vers.
Discus and support W10 Home PCs seeing only Win7 Pro & W10 Pro PCs on LAN, Not Home vers. in Windows 10 Network and Sharing to solve the problem; I have a small Workgroup LAN (Ethernet) with one remaining Win 7 Pro PC (I would like to phase out), 2 - Win 10 Pro PCs, and a few Win 10 Home addition... Discussion in 'Windows 10 Network and Sharing' started by Edward2, Mar 16, 2020.
W10 Home PCs seeing only Win7 Pro & W10 Pro PCs on LAN, Not Home vers. - Similar Threads - W10 Home PCs
W10 Pro downgrade to w10 home
in Windows 10 Updates and ActivationW10 Pro downgrade to w10 home: My laptop came with W10 Home preinstalled by manufacturer. I purchased a windows 10 pro product key and installed. Now selling the laptop and wish to revert to W10 home and apply W10 Pro on new laptop. Is this possible?... -
in Windows 10 GamingW10 Pro downgrade to w10 home: My laptop came with W10 Home preinstalled by manufacturer. I purchased a windows 10 pro product key and installed. Now selling the laptop and wish to revert to W10 home and apply W10 Pro on new laptop. Is this possible?... -
in Windows 10 Software and AppsW10 Pro downgrade to w10 home: My laptop came with W10 Home preinstalled by manufacturer. I purchased a windows 10 pro product key and installed. Now selling the laptop and wish to revert to W10 home and apply W10 Pro on new laptop. Is this possible?... -
Cannot upgrade W10 Home to Pro
in Windows 10 Updates and ActivationCannot upgrade W10 Home to Pro: Hello, I got a refurbished laptop with Win 10 Home and wanted to upgrade it to Pro. I purchased an OEM license and could try to activate it, but I get 0xC004F090 On a computer running Microsoft Windows non-core edition, run ... I tried to use a generic... -
Upgrading W10 Home to W10 Pro
in Windows 10 Installation and UpgradeUpgrading W10 Home to W10 Pro: I bought a new PC and am attempting to upgrade from the W10 Home that came with the PC with a version of W10 Pro that I bought to upgrade my old PC but the new machine will not recognize the software on the flash drive containing the W10 Pro upgrade... -
Upgrading from W10 Home to Pro
in Windows 10 Installation and UpgradeUpgrading from W10 Home to Pro: I am thinking about upgrading to W10 Pro but I have a question. I have 3 computers and they are all about 7 years old so in your opinion would this update be beneficial or should I just buy a new one. Thanks 162616 -
Upgrade W10 Home to PRO ?
in Windows 10 Installation and UpgradeUpgrade W10 Home to PRO ?: I'm needing a workable procdure for this upgrade. Since its been a long time since I purchased a NEW manufactured system (usually build all my own desktops), I know little in what form the machine will be in at power up. Some history first: I have just purchased a Lenovo... -
2 W10 PCs on home network
in Windows 10 Network and Sharing2 W10 PCs on home network: Hello all....can't connect over my home network after updating 1 PCs OS from 7 to 10 10 ProN 18363.476 Network... Everything worked prior to updating the OS on PC 1 Cable modem to netgear 7900 7900 to PC 1 7900 to netgear Proline to PC 2 Same workgroup both PCs are on a... -
W10-pro shows W7-home but NOT W10-home in Explorer
in Windows 10 Network and SharingW10-pro shows W7-home but NOT W10-home in Explorer: My W10-pro desktop does not show the W10-home on the multiboot laptop in Explorer whatever setting I use but it showed W7-home on that laptop as soon as I switched to it. I can Ping the laptop both in W7-home and W10-home. W10-home on the laptop however showes all shared...
