Windows 10: Why does my USB Mic only work when I have it plugged into a USB Hub and not into my Laptop
Discus and support Why does my USB Mic only work when I have it plugged into a USB Hub and not into my Laptop in Windows 10 Software and Apps to solve the problem; I'm trying to understand why my USB microphone only works when it's plugged into my USB hub, but not when I plug it directly into my laptop. When I... Discussion in 'Windows 10 Software and Apps' started by Brandon Meza1, Jun 23, 2025.
  1. Why does my USB Mic only work when I have it plugged into a USB Hub and not into my Laptop
    I'm trying to understand why my USB microphone only works when it's plugged into my USB hub, but not when I plug it directly into my laptop. When I connect the mic straight to the laptop, it's either not recognized at all or doesn't function properly there's no input signal, or the mic shows up but doesn’t record any sound. However, when I plug the mic into the USB hub, it works without any issues. This seems backwards from what I would expect, since direct laptop connections are usually more stable. I’ve tried different USB ports on the laptop, but the result is the same. This makes me wonder
  2. Belkin introduces wireless USB hub
    uh
    • what long wires?
      wow, you dont have to plug a really small thin piece of plastic into your laptop while roaming about...
      dont they already make wireless adapters for these for much cheaper?
    ok...so...
    am i missing something here? almost 200 bucks for this???
    Easy Rhino, Jun 23, 2025
  3. flamer Win User
    No USB ports working on toshiba laptop
    Hi guys,
    Got an old Toshiba laptop, satellite l500d pslk0a-00r009
    Its old and doesn't officially support win10. However I have it installed and everything works fine except USB. All the ports seem completely dead, plugging in a USB mouse I get no light on the mouse. USB flash drives don't work either. This was previously working under win7.
    The issue seems to be I don't have "Generic USB hub" in device manager. Have tried to manually install it using add legacy hardware but it wont take. I have several USB root hub and others listed, but not the generic hub.
    Here's what I have tried so far:
    Uninstall all USB device in device managers and reboot
    Confirmed BIOS is latest version
    tried both legacy and compatibly USB mode in BIOS
    Download and install generic win10 USB drivers
    Disable USB power saving mode
    Installed toshiba's service center, no updates available
    Ran MS troubleshooter/fixit
    I think the next step is to give up, but does anyone else have any suggestions?
    thanks
    flamer, Jun 23, 2025
  4. Why does my USB Mic only work when I have it plugged into a USB Hub and not into my Laptop
    USB HUB
    Incompatible USB hub driver is one of the possible reasons why this issue is happening. We recommend uninstalling the USB Root Hub driver and see if it helps. Follow the stepes below:
    • Open Device Manager.
    • Double-click Universal Serial Bus controllers to expand.
    • Right-click USB Root Hub, then click Properties.
    • Go to the Driver tab.
    • Click Uninstall.
    • Restart your computer.
    Note: Restarting your computer will automatically reinstall a generic driver for your computer. Also, we suggest connecting your USB hub while performing the steps.
    If the issue still persists, let's disable the USB selective suspend settings thru Power Options to resolve the issue. Follow the steps below:
    • Type Power Options in the search box, then press Enter.
    • Locate USB settings > USB selective suspend settings.
    • Select Disable.
    Keep us in the loop with the result.
    Martin Bar, Jun 23, 2025
  1. Why does my USB Mic only work when I have it plugged into a USB Hub and not into my Laptop - Similar Threads - Why does USB
  2. Why does my USB Mic only work when I have it plugged into a USB Hub and not into my Laptop
    Why does my USB Mic only work when I have it plugged into a USB Hub and not into my Laptop: I'm trying to understand why my USB microphone only works when it's plugged into my USB hub, but not when I plug it directly into my laptop. When I connect the mic straight to the laptop, it's either not recognized at all or doesn't function properly there's no input signal,...
  3. Laptop will not shutdown when USB hub is plugged in.
    Laptop will not shutdown when USB hub is plugged in.: When my USB hub with keyboard, mouse, printer, and monitor is plugged into USB-C port, the laptop will go into sleep mode rather than shutdown when selecting Shutdown from menu....
  4. Laptop will not shutdown when USB hub is plugged in.
  5. Why do I only have 1 USB Root Hub on my pc?
    Why do I only have 1 USB Root Hub on my pc?: Why do I only have 1 USB Root Hub on my Pc? https://answers.microsoft.com/en-us/windows/forum/all/why-do-i-only-have-1-usb-root-hub-on-my-pc/53e1d955-f494-4c13-8088-05abd285bfc5
  6. USB mic not working when USB headset is plugged in or connected
    USB mic not working when USB headset is plugged in or connected: I just recently bought a USB mic from Amazon. Its the fifine a6t. Sounds great and really good for the price. It works perfectly when I'm using my speakers to monitor it or use it with it at the same time. But for some reason, when I turn on my wireless headset Corsair...
  7. USB mic not working when USB headset is plugged in or connected
  8. USB mic not working when USB headset is plugged in or connected
  9. Squeaking sound when i plug my speakers into my usb hub
    Squeaking sound when i plug my speakers into my usb hub: Hey, I have recently bought a new 7-port USB hub, it was working perfectly fine with all my devices, except my speakers, when I plugged it in, it made a high-pitch squeaking sound, even when the volume is on mute, it works fine when plugged directly through one of my...
  10. used Spro1 - usb drives only work when in a usb hub?
    used Spro1 - usb drives only work when in a usb hub?: i received the surface pro 1 today, but there is a strange problem with it. USB drives are not recognised when directly connected to spro1 like they should be. They are not visible in file explorer, device manager or disk management. only when put through a non-powered USB...
