Windows 10: Why does power slider recommends greater power in battery than when plugged in?
Discus and support Why does power slider recommends greater power in battery than when plugged in? in Windows 10 Customization to solve the problem; The Windows 10 power slider shows a recommended power setting that is higher when on battery than when plugged. The reason is not intuitive for me.... Discussion in 'Windows 10 Customization' started by jaygourley, Oct 22, 2019.
Why does power slider recommends greater power in battery than when plugged in? - Similar Threads - Why does power
Laptop crashed when plugged in on power with no battery plugged in
in Windows 10 Performance & MaintenanceLaptop crashed when plugged in on power with no battery plugged in: Hie . My laptop carshes every 5-10min when ever i am working on it. First is checked with The power is plugged in and the battery also it crashed. Then i removed the battery and connected directly to power plugged in it crashes again. Can anyone help me figure out what is the... -
in Windows 10 GamingLaptop crashed when plugged in on power with no battery plugged in: Hie . My laptop carshes every 5-10min when ever i am working on it. First is checked with The power is plugged in and the battery also it crashed. Then i removed the battery and connected directly to power plugged in it crashes again. Can anyone help me figure out what is the... -
in Windows 10 Software and AppsLaptop crashed when plugged in on power with no battery plugged in: Hie . My laptop carshes every 5-10min when ever i am working on it. First is checked with The power is plugged in and the battery also it crashed. Then i removed the battery and connected directly to power plugged in it crashes again. Can anyone help me figure out what is the... -
Removing battery power mode sliders
in Windows 10 CustomizationRemoving battery power mode sliders: Hello, I wonder if its possible to remove those power sliders in battery icons because they do mess up with certain things for me, i would like to just run on balanced power plan without the need of those things, Thanks in advance.... -
in Windows 10 GamingRemoving battery power mode sliders: Hello, I wonder if its possible to remove those power sliders in battery icons because they do mess up with certain things for me, i would like to just run on balanced power plan without the need of those things, Thanks in advance.... -
in Windows 10 Software and AppsRemoving battery power mode sliders: Hello, I wonder if its possible to remove those power sliders in battery icons because they do mess up with certain things for me, i would like to just run on balanced power plan without the need of those things, Thanks in advance.... -
Battery Power slider missing.
in Windows 10 Performance & MaintenanceBattery Power slider missing.: As the title says, the battery slider in Windows 10 is missing. It was there a few days ago but today when I checked it, it wasn't. I haven't changed anything recently in the power options. I checked the internet for a fix, but all of them are nothing but "keep the power... -
Battery Slider vs Power Options
in Windows 10 Performance & MaintenanceBattery Slider vs Power Options: What bearing if any does the slider have on the power options (from control panel) I slid it to better battery but the power plan was still set to balanced? Are they completely independent? I needed to leave my laptop on over night and the fan kept starting up (not sure... -
Why does battery power icon says "plugged in, not charging"?
in Windows 10 CustomizationWhy does battery power icon says "plugged in, not charging"?: Why does battery power icon says "plugged in, not charging"? https://answers.microsoft.com/en-us/windows/forum/all/why-does-battery-power-icon-says-plugged-in-not/952a088f-adec-4111-b860-e1f64927b3c3
power slider windows when plugged in
,do i set windows power slider as well as power plan?
