Windows 10: Why no USB Settings in Advanced Power Settings?
Discus and support Why no USB Settings in Advanced Power Settings? in Windows 10 Performance & Maintenance to solve the problem; My wife's Dell computer has a lot more options in the Advance Power settings. Including "USB Settings". Why would my HP Envy 32 not have those... Discussion in 'Windows 10 Performance & Maintenance' started by MarkTiede, Jan 24, 2021.
Why no USB Settings in Advanced Power Settings? - Similar Threads - Why USB Settings
Advanced Power Plan setting not working
in Windows 10 GamingAdvanced Power Plan setting not working: Hi,Since my last Windows 11 update to version 22H2, my PC does NOT automatically go to sleep. It sleep on if I use the CTRL + F1 keys of my keyboard.When I try to use the Advanced Power Plan Setting to High Performane, the Apply Button does not highlight and my Power Setting... -
in Windows 10 Software and AppsAdvanced Power Plan setting not working: Hi,Since my last Windows 11 update to version 22H2, my PC does NOT automatically go to sleep. It sleep on if I use the CTRL + F1 keys of my keyboard.When I try to use the Advanced Power Plan Setting to High Performane, the Apply Button does not highlight and my Power Setting... -
Advanced power settings help
in Windows 10 CustomizationAdvanced power settings help: Hello a few months ago i downlaoded AVG battery saver lnto my laptop and i deleted it awhile sgo snd now its still being used on my laptop even though the app isnt on my laptop. everytime i turn my laptop on the battery lowers and i looked on my advanced power settings and... -
USB Power settings - WHY!???
in Windows 10 Drivers and HardwareUSB Power settings - WHY!???: OK a little bit of a rant and reporting and issue that should never have happened. This happened to my son who depends on things like live streaming for his income as a professional musician. I'm a former MSFT consultant and assisted with this troubleshooting over a the... -
in Windows 10 Customizationadvanced power settings: Hi all, Its very frustrating that I am not getting all the options in x1 yoga 3rd gen computer. i have tried powercfg -attributes 19cbb8fa-5279-450e-9fac-8a3d5fedd0c1 12bbebe6-58d6-4636-95bb-3217ef867c1a -attrib_hide for showing the wireless option but no luck ! tried... -
No USB in Power Options, Advanced settings
in Windows 10 Performance & MaintenanceNo USB in Power Options, Advanced settings: I have an ASUS Zenbook, Windows 10 Home 64bit. I wanted to adjust the USB settings, specifically to have the USB shutoff while in sleep mode. I believe the USB is still being powered as my battery drains when I have a mouse plugged in, even it is off. Originally my problem... -
Change Advanced Power Settings in Windows 10 does not contain USB settings
in Windows 10 Performance & MaintenanceChange Advanced Power Settings in Windows 10 does not contain USB settings: My laptop does not recognize when I USB connect the tablet and I am trying all the fixes recommended. One of them is to change the USB suspend power plan settings but my Change Advanced Power Settings in Windows 10 does not contain USB settings at all. How can I access them?... -
Can not change Advanced Power Settings
in Windows 10 CustomizationCan not change Advanced Power Settings: I have switch to the high performance power plan but I want to change a few of the advanced power settings but when I click on it nothing happens no menu, nothing!... -
Problem with Advanced Power Settings
in Windows 10 SupportProblem with Advanced Power Settings: I bought a used computer, updated to Windows 10. It runs great for what i use it for, but i noticed the CPU was running hot. Core #0 runs at 99c at full load such as watching a movie. I did my own research and decided to change the processor power management . So I go into my...
