Windows 10: wifi and battery indicator keep being removed from bar
Discus and support wifi and battery indicator keep being removed from bar in Windows 10 Support to solve the problem; Several times they have disappeared and been turned off as in they dont show up. WHY ? And I forgot how to make the indicators be visible on the task... Discussion in 'Windows 10 Support' started by sdowney717, Jun 25, 2019.
wifi and battery indicator keep being removed from bar - Similar Threads - wifi battery indicator
Battery indicator fluctuate
in Windows 10 Software and AppsBattery indicator fluctuate: HiI recently purchased the Samsung galaxy book pro 360 2 in 1 laptop 13.3-inch screen. The device works perfectly with windows 11 except for the battery. First of all, the battery life is very poor and does not match the claim in the specs of 22 hours battery life. But my... -
Battery indicator
in Windows 10 CustomizationBattery indicator: After the motherboard was replaced my battery indicator shows time left for full charge instead of battery power percentage. How can I change this? https://answers.microsoft.com/en-us/windows/forum/all/battery-indicator/d5c1a88e-c8bd-43ee-b56d-902e71842aca -
Battery indicator
in Windows 10 Installation and UpgradeBattery indicator: Ever since the Microsoft 10 update my battery never shows 100% charged. How do I fix this? https://answers.microsoft.com/en-us/windows/forum/all/battery-indicator/9c8c02b6-4675-47d5-9bea-ba65732431c2 -
battery not charging indicator
in Windows 10 BSOD Crashes and Debuggingbattery not charging indicator: Hello. Not sure which topic this should be posted under; please redirect me if need be. After updating a couple of days ago, the battery indicator says "XX% available (plugged in, not charging). I tested the battery and there doesn't appear to be any fault. I'm guessing... -
battery charge indicator no longer on tool bar?
in Windows 10 Customizationbattery charge indicator no longer on tool bar?: Battery charge indicator no longer on tool bar after last update. https://answers.microsoft.com/en-us/windows/forum/all/battery-charge-indicator-no-longer-on-tool-bar/81370439-3195-4db4-9d9a-f750385d9589 -
Battery indicator
in Windows 10 CustomizationBattery indicator: How to keep battery indicator in taskbar? https://answers.microsoft.com/en-us/windows/forum/all/battery-indicator/0cbf90ee-54d9-4f7a-a23e-b48f3eae3526 -
battery life indicator not shown in task bar
in Windows 10 Performance & Maintenancebattery life indicator not shown in task bar: battery life indicator not shown in task bar. but in settings the option is turned on. please help https://answers.microsoft.com/en-us/windows/forum/all/battery-life-indicator-not-shown-in-task-bar/220b7e7d-c130-4ddb-a0d4-9d75aa4beefe -
in Windows 10 Customizationbattery life indicator: where is the battery life indicator that was always on the taskbar? https://answers.microsoft.com/en-us/windows/forum/all/battery-life-indicator/cba1c651-cc3f-4146-abf5-eff2be409e54 -
Battery level indicator on task bar
in Windows 10 CustomizationBattery level indicator on task bar: One day, my battery level indicator in my notification area disappeared. Then my network status icon disappeared. I believe these events happened because of updates. I played with the many settings menus that Windows has to offer and was able to turn the network icon back...
