Windows 10: Wireless keyboard with Caps Lock LED
Discus and support Wireless keyboard with Caps Lock LED in Windows 10 Drivers and Hardware to solve the problem; My Windows version is 1909. Can anyone recommend a wireless keyboard, preferable with UK layout, that has a Caps Lock LED. I am fed up with passwords... Discussion in 'Windows 10 Drivers and Hardware' started by geoffL, Jul 11, 2020.
Wireless keyboard with Caps Lock LED - Similar Threads - Wireless keyboard Caps
Caps lock freezes keyboard
in Windows 10 Software and AppsCaps lock freezes keyboard: Hi. When I press caps lock, my laptop keyboard freezes and it seems activates the Windows key at the same time. It also brings up speech recognition, multiple display function, and starts typing '8' on repeat if a text box is available. When I used a keyboard tester, it seems... -
in Windows 10 Drivers and HardwareCaps lock freezes keyboard: Hi. When I press caps lock, my laptop keyboard freezes and it seems activates the Windows key at the same time. It also brings up speech recognition, multiple display function, and starts typing '8' on repeat if a text box is available. When I used a keyboard tester, it seems... -
My keyboard caps lock led not working after update
in Windows 10 GamingMy keyboard caps lock led not working after update: Normally, when I press caps lock key, all keyboard turns red but this doesn't happen after the update. Upgrading to the old version solves the problem. is there any way to fix this problem ?version is Windows 11 pro Insider Build 22494.rs_prerelease.211029-1421Keyboard ANNE... -
in Windows 10 Software and AppsMy keyboard caps lock led not working after update: Normally, when I press caps lock key, all keyboard turns red but this doesn't happen after the update. Upgrading to the old version solves the problem. is there any way to fix this problem ?version is Windows 11 pro Insider Build 22494.rs_prerelease.211029-1421Keyboard ANNE... -
keyboard caps lock
in Windows 10 Drivers and Hardwarekeyboard caps lock: hello when I type words in on my keyboard it will stay in the correct caps setting but when I change it it stays for about an extra 3-5 minutes before changing to the setting of the correct cap. this has become a problem as recently it has caused me to slow down when... -
Keyboard caps lock
in Windows 10 Software and AppsKeyboard caps lock: I have just bought a keyboard with larger characters on the keys and its good except for one small niggle. The warning light for caps lock is very small. I am a one fingered typist, and don't look at the screen until I have at least completed a sentence. This results in a lot... -
Caps Lock key no longer working on new wireless keyboard
in Windows 10 Drivers and HardwareCaps Lock key no longer working on new wireless keyboard: Having just purchased a new wireless keyboard and mouse I now find that the Caps Lock key no longer works. The Shift key works and so does the Num Lock key. My OS is Windows 10 64 bit and is full updated. Any suggestions how to fix this will be gratefully received. Dave... -
keyboard num/caps/scrl lock leds off
in Windows 10 Drivers and Hardwarekeyboard num/caps/scrl lock leds off: After a clean win 10 pro install, the leds don't come on until I unplug/plug the keyboard.Tried uninstalling board, usb, disabling fast start. No luck. https://answers.microsoft.com/en-us/windows/forum/all/keyboard-numcapsscrl-lock-leds-off/a82ddd9d-2169-4bb4-bc9b-1474f9480d7a -
wireless 3050 keyboard caps lock light?
in Windows 10 Drivers and Hardwarewireless 3050 keyboard caps lock light?: hello just purchased this key board and cant find or see an indicator light to show if im in caps or not... do i have to turn this function on? https://answers.microsoft.com/en-us/windows/forum/all/wireless-3050-keyboard-caps-lock-light/dda0cf0f-f7b0-4ada-a496-864241011869
