Windows 10: Xbox controller USB cable problem PC
Discus and support Xbox controller USB cable problem PC in Windows 10 Drivers and Hardware to solve the problem; Hi All, I'm having a very strange issue with my controller to PC situation. It will only work with one micro USB cable. I was using the controller the... Discussion in 'Windows 10 Drivers and Hardware' started by RickyMandair, Oct 22, 2021.
Xbox controller USB cable problem PC - Similar Threads - Xbox controller USB
Xbox controller USB cable problem PC Win10
in Windows 10 Drivers and HardwareXbox controller USB cable problem PC Win10: Hi All, I'm having a very strange issue with my controller to PC situation. It will only work with one micro USB cable. I was using the controller the evening before, did not turn the PC off and in the morning the light had turned off and it was unresponsive and no longer... -
in Windows 10 GamingXbox controller USB cable problem PC Win10: Hi All, I'm having a very strange issue with my controller to PC situation. It will only work with one micro USB cable. I was using the controller the evening before, did not turn the PC off and in the morning the light had turned off and it was unresponsive and no longer... -
in Windows 10 Software and AppsXbox controller USB cable problem PC Win10: Hi All, I'm having a very strange issue with my controller to PC situation. It will only work with one micro USB cable. I was using the controller the evening before, did not turn the PC off and in the morning the light had turned off and it was unresponsive and no longer... -
in Windows 10 GamingXbox controller USB cable problem PC: Hi All, I'm having a very strange issue with my controller to PC situation. It will only work with one micro USB cable. I was using the controller the evening before, did not turn the PC off and in the morning the light had turned off and it was unresponsive and no longer... -
in Windows 10 Software and AppsXbox controller USB cable problem PC: Hi All, I'm having a very strange issue with my controller to PC situation. It will only work with one micro USB cable. I was using the controller the evening before, did not turn the PC off and in the morning the light had turned off and it was unresponsive and no longer... -
Xbox one Controller wont connect to Pc via USB cable
in Windows 10 GamingXbox one Controller wont connect to Pc via USB cable: Hi, so i have an xbox one controller, and ive been using usb to play with my pc, but just recently it just stopped working for some reason. The controller recieves power but when i press and hold the xbox button it continues to idle, and not stay static. The drivers have been... -
in Windows 10 Software and AppsXbox one Controller wont connect to Pc via USB cable: Hi, so i have an xbox one controller, and ive been using usb to play with my pc, but just recently it just stopped working for some reason. The controller recieves power but when i press and hold the xbox button it continues to idle, and not stay static. The drivers have been... -
in Windows 10 Drivers and HardwareXbox one Controller wont connect to Pc via USB cable: Hi, so i have an xbox one controller, and ive been using usb to play with my pc, but just recently it just stopped working for some reason. The controller recieves power but when i press and hold the xbox button it continues to idle, and not stay static. The drivers have been... -
XBOX One Controller only works with one USB Cable
in Windows 10 Drivers and HardwareXBOX One Controller only works with one USB Cable: I play a few games on my Windows 10 machine with an XBOX one controller. I usually have the same cable plugged into the controller, and unplug it from the machine occasionally when I need to free up a port. Well the other day I wanted to charge my tablet so I grabbed the...
