Windows 10: Right click on start menu problem
Discus and support Right click on start menu problem in Windows 10 Support to solve the problem; Hi, I have a very strange problem in Win 10 Pro RTM: when I right click on the start menu and the conext menu appears like this: [img] the... Discussion in 'Windows 10 Support' started by pompeyon, Jul 31, 2015.
Right click on start menu problem - Similar Threads - Right click start
Start menu right click menu not highlighting
in Windows 10 GamingStart menu right click menu not highlighting: When I go to the start menu, type in an application like cmd, then try to right click, the menu no longer highlights. Is there a fix for this problem? Thank you.... -
in Windows 10 Software and AppsStart menu right click menu not highlighting: When I go to the start menu, type in an application like cmd, then try to right click, the menu no longer highlights. Is there a fix for this problem? Thank you.... -
Right-click on start menu
in Windows 10 GamingRight-click on start menu: When I right-click on the Start menu in Windows 10, it brings up the options menu and when I select Task manager nothing happens. This also happens when I try to select Device Manager, Event Viewer, Disk Manager, Computer Manager, Windows Powershell and Admin, and File... -
in Windows 10 Software and AppsRight-click on start menu: When I right-click on the Start menu in Windows 10, it brings up the options menu and when I select Task manager nothing happens. This also happens when I try to select Device Manager, Event Viewer, Disk Manager, Computer Manager, Windows Powershell and Admin, and File... -
in Windows 10 BSOD Crashes and DebuggingRight-click on start menu: When I right-click on the Start menu in Windows 10, it brings up the options menu and when I select Task manager nothing happens. This also happens when I try to select Device Manager, Event Viewer, Disk Manager, Computer Manager, Windows Powershell and Admin, and File... -
the right click menu problem.
in Windows 10 Gamingthe right click menu problem.: Hello,I notice that there is missing part of my right click menu as you can see from the picture above, can someone help me with that please?thanks in advance. https://answers.microsoft.com/en-us/windows/forum/all/the-right-click-menu-problem/8fcf77cd-8c77-41da-9c6e-16f3f1e37990 -
in Windows 10 Software and Appsthe right click menu problem.: Hello,I notice that there is missing part of my right click menu as you can see from the picture above, can someone help me with that please?thanks in advance. https://answers.microsoft.com/en-us/windows/forum/all/the-right-click-menu-problem/8fcf77cd-8c77-41da-9c6e-16f3f1e37990 -
Start Menu - Right-Click
in Windows 10 SupportStart Menu - Right-Click: Hello,In the "Start Menu" there are two types of icons - one is a square with a folder icon on it, the other is a square with the program's icon.Now 'folder icons' have no right-click sub-menu, the others with a program icon have a right-click sub-menu.In the sub-items of a... -
Right click Start Menu
in Windows 10 CustomizationRight click Start Menu: Last few insider builds (not necessarily because of it) Most of items in Start menu's just don't do anything. Command prompt/, Disk management, Device manager, Task manager etc. Other shortcuts for them work, each one when started from anywhere else works. I made links for...
