Windows 10: Power and volume icon greyed out
Discus and support Power and volume icon greyed out in Windows 10 Support to solve the problem; I can't activate the power and volume icon because there gray. I've tried the regedit method. The icons came back but disapeared at the next booth. Is... Discussion in 'Windows 10 Support' started by turg, Nov 7, 2015.
Power and volume icon greyed out - Similar Threads - Power volume icon
power icon toggle is greyed out
in Windows 10 Gamingpower icon toggle is greyed out: I checked my battery icon and it's showing off. When I check on the settings to turn it on, the toggle is greyed out and cannot turn it back on. Restarting will fix it, but will happen again eventually. I need permanent fix. Thankyou.... -
in Windows 10 Software and Appspower icon toggle is greyed out: I checked my battery icon and it's showing off. When I check on the settings to turn it on, the toggle is greyed out and cannot turn it back on. Restarting will fix it, but will happen again eventually. I need permanent fix. Thankyou.... -
in Windows 10 Customizationpower icon toggle is greyed out: I checked my battery icon and it's showing off. When I check on the settings to turn it on, the toggle is greyed out and cannot turn it back on. Restarting will fix it, but will happen again eventually. I need permanent fix. Thankyou.... -
Power Icon Slider is Greyed Out?
in Windows 10 CustomizationPower Icon Slider is Greyed Out?: I noticed my Taskbar Battery Icon is off and when I went to settings to turn it back on I found the Slider Greyed out. Is a restart the only way to fix it? This seems to happen more & more. Any reason?... -
in Windows 10 GamingPower Icon Slider is Greyed Out?: I noticed my Taskbar Battery Icon is off and when I went to settings to turn it back on I found the Slider Greyed out. Is a restart the only way to fix it? This seems to happen more & more. Any reason?... -
in Windows 10 Software and AppsPower Icon Slider is Greyed Out?: I noticed my Taskbar Battery Icon is off and when I went to settings to turn it back on I found the Slider Greyed out. Is a restart the only way to fix it? This seems to happen more & more. Any reason?... -
power icon greyed out on laptop
in Windows 10 Customizationpower icon greyed out on laptop: The toolbar is currently not showing the power icon and I am unable to estimate the battery life. In the settings, the power icon is greyed out and I am not able to toggle it. Kindly help.... -
Power Icon greyed out
in Windows 10 CustomizationPower Icon greyed out: Im running windows 10 home - version 1803 (updated earlier this month) and cant seem to get the power icon displaying so I can check my battery status. Ive gone to Settings, Personalization but the only icon that is greyed out is the one I want - why is it greyed out?... -
Power icon and music icon greyed out?
in Windows 10 SupportPower icon and music icon greyed out?: So for about a week my laptop decided that it would remove the music and power icon from the task-bar so, I went into notifications settings to turn it back on but the icons were grayed out. So i went to the inter-webs to find guides but none worked. One guide however did...
